Impedance of N Pi networks
Samantha Groves
Joined Nov 25, 2023
162
Suppose we have N Pi networks connected with each other:
Is there a forumula to calculate the resistance of the whole N-Pi network?Thanks
ZCochran98
Joined Jul 24, 2018
356
Interesting that this question should come up, given I was working on this exact problem a couple weeks ago (though with reactances rather than resistances). There's a way I know how to do it, but it's painful, and ultimately uses a lot of auxiliary variables. We can re-draw this slightly. If we have two identical resistors in parallel, then we know the equivalent resistance is half the resistance. So let's replace every instance of \(R_1\) with a set of parallel \(2R_1\). That lets us create a series of identical \(\Pi\) network elements cascaded together. In the attached picture, I have the original circuit (top), the equivalent "mid-step" circuit (middle), and the final equivalent circuit (bottom) shown.
Notice how I have each cascaded subsection boxed in and labelled 'A' - this is in reference to the transfer matrix I'm going to derive for that subsection, which I'll label as matrix \(A\). The transfer matrix is of the form:
\left[ \begin {array}{c} V_{2}\\-I_{2}\end {array}
\right] =
\left[ \begin {array}{cc} \alpha_{11}&\alpha_{12}
\\ \alpha_{21}&\alpha_{11}\end {array} \right]
\left[ \begin {array}{c} V_{1}\\I_{1}\end {array}
\right]
Where \(V_1\) is the voltage across the left terminals of the block, \(I_1\) is the current flowing INTO the left side of the block, \(V_2\) is the voltage across the right terminals of the block, and \(-I_2\) is the current flowing OUT OF the right side of the block. Here, we define:
\[A =
Where (if I did my math right - you may want to check!)
\[\alpha_{11} = \alpha_{22} = \frac{R_2}{2R_1} + 1 \]
\[\alpha_{12} = -R_2\]
\[\alpha_{21} = -\frac{1}{R_1}\left(\frac{R_2}{4R_1}+1\right)\]
Cascading \(N\) of these together (for the cumulative effect to get the primed values) requires a bit of matrix trickery (eigendecomposition for the simplest way I'm aware of - \(A = \mathscr{V}\Lambda\mathscr{V}^{-1}\), where \(\mathscr{V}\) is the eigenvector matrix of \(A\) and \(\Lambda\) is the diagonal eigenvector matrix of \(A\)) to get us to the following definitions for \(A' \equiv A^N = \mathscr{V}\Lambda^N\mathscr{V}^{-1}\):
\[\lambda_\pm = \alpha_{11} \pm \sqrt{\alpha_{12}\alpha_{21}}\]
\[\alpha_{11}' = \alpha_{22}' = \frac{1}{2}\left(\lambda_+^N + \lambda_-^N\right)\]
\[\alpha_{12}' = -\frac{1}{2}\sqrt{\frac{\alpha_{12}}{\alpha_{21}}}\left(\lambda_+^N - \lambda_-^N\right)\]
\[\alpha_{21}' = -\frac{1}{2}\sqrt{\frac{\alpha_{21}}{\alpha_{12}}}\left(\lambda_+^N - \lambda_-^N\right)\]
From here, we can take the primed \(\alpha\) values and reverse-engineer an effective set of \(R_1'\) and \(R_2'\) from the original definitions of the \(\alpha\) values to get us to the bottom equivalent circuit. Doing so gives us:
\[R_2' = -\alpha_{12}'\]
\[R_1' = \frac{R_2'}{2\left(\alpha_{11}'-1\right)} = -\frac{\alpha_{12}'}{2\left(\alpha_{11}'-1\right)}\]
So the total equivalent resistance becomes:
\[R_T = \left(\frac{1}{2R_1} + \frac{1}{2R_1'} + \frac{1}{R_2 + \frac{2R_1'R_1}{R_1'+R_1}}\right)^{-1}\]
I did not bother putting \(R_1'\) and \(R_2'\) in terms of \(R_1\) and \(R_2\) because the equation becomes horrifically complicated. In order to keep it "simple," it needs all the auxiliary variables.
If there IS a simpler way to do this, then I personally don't know it.
Samantha Groves
Joined Nov 25, 2023
162
\right] =
\right]
\[A =
So what is \[ R_1^{'} \] equivalent to as a function of \[ N \]?
ZCochran98
Joined Jul 24, 2018
356
Originally, I was attempting to avoid writing that out, as the equation is a nightmare. But here they are:
\[R_1' =
-{\frac {R_{1}\,\sqrt {R_{2}} \left( \left( -1 \right) ^{N} \left( -R
_{2}-2\,R_{1}+\sqrt {R_{2}\, \left( R_{2}+4\,R_{1} \right) } \right) ^
{N}- \left( R_{2}+2\,R_{1}+\sqrt {R_{2}\, \left( R_{2}+4\,R_{1}
\right) } \right) ^{N} \right) }{\sqrt {R_{2}+4\,R_{1}} \left( -{2}^{
1+N}{R_{1}}^{N}+ \left( -1 \right) ^{N} \left( -R_{2}-2\,R_{1}+\sqrt {
R_{2}\, \left( R_{2}+4\,R_{1} \right) } \right) ^{N}+ \left( R_{2}+2\,
R_{1}+\sqrt {R_{2}\, \left( R_{2}+4\,R_{1} \right) } \right) ^{N}
\right) }}
\[R_2' =
-{\frac {{R_{1}}^{1-N}\sqrt {R_{2}}{2}^{-N} \left( \left( -1 \right)
^{N} \left( -R_{2}-2\,R_{1}+\sqrt {R_{2}\, \left( R_{2}+4\,R_{1}
\right) } \right) ^{N}- \left( R_{2}+2\,R_{1}+\sqrt {R_{2}\, \left( R
_{2}+4\,R_{1} \right) } \right) ^{N} \right) }{\sqrt {R_{2}+4\,R_{1}}}
Thankfully, I have access to some CAS tools, so I did not have to do all that substitution by hand.
WBahn
Joined Mar 31, 2012
33,236
You can get some bounding approximations pretty easily.
For infinite N, first pull off the left-most R1 (add it back later) and then use the trick that the resistance looking into R2 is R2 + R1||(everything to the right). Call the resistance of everything to the right Ro. Since it is infinite, Ro is also the resistance looking into R2. So you have
Ro = R2 + (R1||Ro)
This results in a quadratic with one positive real root.
Ro = R2 * (1 + sqrt(1 + 4(R1/R2))/2
Notice that if R1=R2, then the multiplier is the Golden Ratio.
You can now put Ro in parallel with R1 and you have the lowest value that your resistance can be.
28,365
This looks a lot like classwork problem for the second-semester third year engineering course, "advanced math", after all the calculus and differential equations stuff. What came close was transmission line analysis with reactance instead of resistance. I never had to deal with that in my engineering career, but I never had to design antenna arrays, either.
ZCochran98
Joined Jul 24, 2018
356
TBH I thought so too, but I also know a lot of universities are on break at the moment for the holidays.
