Impedance matching with only resistor
Anastasios Kyriakidis
Joined Feb 5, 2019
Hi all,
A relatively 'silly' question but I am trying to find out why that happens and I couldn't till now.
I know of course that usually a resistor is used in series to match the impedance of the transmission line with the load.
My question is why that is always a resistor? Impedance means: resistor, capacitance, inductance. Capacitance and inductance also change, depending on the trace's length. How can a single resistor, which can only match resistance, match reactance too?
Resistors for 'matching' are used when the transmission of power is not important but signal integrity (reflections, ringing, ...) is. The inexpensive resistor acts as a broadband damper for signal mismatch reflections over a wide range of signal speeds.
http://www.ti.com/lit/an/scba012a/scba012a.pdf
Output-Damping Resistors
The purpose of integrating output-damping resistors in line buffers and drivers is to suppress signal undershoots and overshoots on the transmission line through what is usually referred to as line-impedance matching (see Figure 1). The effective output impedance of the line driver (ZO) is matched with the line impedance (ZL). Thus, no signal reflection occurs at the line start (ZO = ZL; reflection coefficient at point A is 0). The input impedance of the receiving device (ZI) is assumed to be several orders of magnitude higher than the line impedance. This is valid for CMOS and BiCMOS devices. In this case, the reflection coefficient at point B is approximately 1, such that almost all of the wave energy is reflected at the end of the line.
38,813
Because the capacitance and inductance of a transmission line create a combined impedance the appears to be largely resistive.
For a lossless transmission line (which is a reasonable approximation for most lines at their designed operating frequencies) the characteristic impedance is
which is independent of frequency and thus can be matched with a resistance at the ends of the line.
See this for a complete explanation.
Joined Feb 5, 2019
You 're the best, thanks!
