I'm confused about (JST?)connector sizes
whitehaired novice
Joined Jul 15, 2017
289
Sometime back I bought a Li-ion charger which came with six small two pin female sockets mounted on a board. A search found what turned out to be a usable male plug which I am sure was called JST. Today I got a meter which has sockets which look much like the earlier ones except these have what is clearly wider spacing. After much head scratching I realized that the meter pins are the same distance apart as a standard DIP. What do I buy to get two pin female sockets in this size?
Thanks.
Zoe123
Joined May 20, 2019
5
You need to measure the pitch, the number of interfaces and interface shape, the overall size of the connector, the appearance. If there is a model, look for an agent or the original factory to buy, if there is no model, you can only enter the brand's official website to find the information you can provide.
jpanhalt
Joined Jan 18, 2008
11,087
The search for a matching connector can be arduous. There are a lot of them. JST is one company (http://www.jst.com/index.html) and its style of connector is often called a JST connector without knowing that it is actually made by JST. Molex and TE Connectivity are two other companies. Go to DigiKey.com and search on "connector." Then climb that tree and see how many choices there are.
A picture plus dimensions will help, but there is still plenty of legwork to do.
whitehaired novice
Joined Jul 15, 2017
289
Well, I'm pretty sure it is this one JST XH2.54 2 Pin Connector Plug. The key seems to be the 2.54 which is, apparently, the pin spacing.
Thanks for your help.
jpanhalt
Joined Jan 18, 2008
11,087
???? 2.54 mm (0.1" ) used to be extremely common -- perhaps the most common worldwide until things got smaller. All of the major US manufacturers still make that size.
Is there some reason you cannot post a picture?
BobTPH
Joined Jun 5, 2013
11,570
I have had problems with matching JST connectors myself. I think they come in both 2mm and 2.54mm which are hard to distinguish by sight.
Bob
jpanhalt
Joined Jan 18, 2008
11,087
Bob
Aw, come on man. 2.54 v. 2.0 mm? What are you, a retired carpenter? JST also offers 2.50 mm vs. 2.54 mm. Now, THAT requires a good eye. ;)
Post a pic with a ruler or for that matter, a standard DIP IC oriented in the same way, With a known dimension in the pic, diminsions can be obtained. Some of us will likely recognize the connector.
