If we multiply each side of a triangle by two, the angles inside the triangle will?
jpanhalt
Joined Jan 18, 2008
11,087
What have you done so far?
Hint: Consider a triangle with sides of 1,2,3. Does it matter what units are used for those measures?
John
tjohnson
Joined Dec 23, 2014
611
1-double
2-halves
3-reduce by √2
4-not change
Kind of confused, haven't do this since high school. lol
Assuming that the units stay the same (which seems highly probable to me), it's not difficult to figure out the answer to your question. Just draw two simple triangles (like 45-45-90 ones), one with sides of length x and another with sides of length 2x, and then measure the angles with a protractor.
Note: I know what the correct answer is, but it would be unethical for me to give it away.
jpanhalt
Joined Jan 18, 2008
11,087
I don't think it is a good idea to try to prove something using an example that might well be a special case. The proof should apply to any triangle.
If you have studied lines intersecting parallel lines, you might find those properties useful here.
I am assuming this a geometry class, not trigonometry, right?
John
tjohnson
Joined Dec 23, 2014
611
I just mentioned 45-45-90 triangles as an example because they might be simpler to draw, but any triangle will work.
@jpanhalt: Are you saying that you think a 45-45-90 triangle would be a special case? I didn't think it would for this proof, but maybe I'm misunderstanding the OP.
33,207
The point is that if you choose fifteen triangles and show that it works for those fifteen triangles, you haven't proven that it will work for anything other than those fifteen triangles. You may have made a very strong case that it probably would work for all triangles, but you haven't "proven" anything.
tjohnson
Joined Dec 23, 2014
611
Right. I wasn't recommending a way to make a proof, since I didn't think that's what the OP was talking about. I was assuming that he just wants to find the answer to an individual problem, but it would be an excellent idea to research the reasoning behind the proof as well.
MrAl
Joined Jun 17, 2014
13,801
Yeah, like linear magnification. If you look at a triangle through a telescope it still looks the same.
Trigonometry has a lot to do with ratios rather than absolute values.
