Advice on how to ground each 8 bit output using Mosfets ?
gray-b
Joined Aug 4, 2025
89
I am using Vcc 12v and have a CD4022 giving 8 bits output. Each of the outputs needs to be connected to a DYHV20T PLAYER module. This module gives out 3.3v. These signals each need grounding but only 1 at a time.
I plan on using mosfets driven by the 12v signals given out by the CD4022. I have plenty of IRLZ44's N type (that I do not mind blowing up), but I am unsure of a recognised schematic. Need to be in open-drain MOSFET configuration, whatever that means??
Do I need 12v onto drain or would the 3.3v suffice, and being pulled to earth?
38,912
You don't need a drain connection to 12V.
Just connect the drain directly to the 3.3V signal.
The MOSFET then acts as a switch to ground.
gray-b
Joined Aug 4, 2025
89
I had got that down as a possible circuit, but could not find any confirmation on Google.
Thanks for quick response.
38,912
I am using Vcc 12v
Just use an inverter after each output. You don’t need discrete MOSFETS.
Use a 74LVC07 (or 74LVC05 if you want it inverting)
Neither recommended for a Vcc of 12V for the gates.
The CD4022 could possibly be used with Schottky diode isolators on the output.
The should pull the output below 0.5V when low which likely is sufficient for a DYHV20T input low logic level.
ci139
Joined Jul 11, 2016
2,037
? 4/3x https://www.nexperia.com/product/HEF7069UBT (ancient // open drain 4069)
? 4x https://www.analog.com/en/products/lt1015.html (may be avail // would be an overkill compared to CD4000 series speed)
it seems TLV1872 is a bit slower analog of the LT1015
(there might be more suitable open collector or open drain comparators LM339 is likely faster than tlv1704)
? 4x https://www.infineon.com/part/2N7002DW (there might be more suitable mosfet matrix ic-s)
update : it looks the mosfets are bloody slow
gray-b
Joined Aug 4, 2025
89
Interesting stuff.
How could I use CD4030 or CD4070 – Quad 2-input open-collector XOR gates.
My Vcc is 12v
I assume the insides of these CD chips are similar to
So again, I assume to ground my 3.3v signal, all I would need to is to apply it to the collector of the output transistor. Not sure if a resistor would be needed.
The logic does not quite work out, as I need only 1 input to be high for the output pin to be 0. This would mean the other input pin is to be tied to 0volts GND
ElectricSpidey
Joined Dec 2, 2017
3,362
Forget the logic chips and just use a load driver as I posted.
You get 8 MOSFETS in a single chip.
They have their inputs (gates) directly across from their outputs (drains).
But I mean, if simplicity, convenience and ease are not your thing...then go ahead and knock yourself out.
38,912
My Vcc is 12v
No.
Those chips are essentially identical and neither is open-collector output.
They have the normal push-pull complementary transistor output stage.
gray-b
Joined Aug 4, 2025
89
Hi ya, are you referring to TBD62083A. It says these only have 8 x Darlington transistor array and no mosfets, the datasheet refers to 8 open-collector outputs (can sink current). But in looking at the typical circuits, it shows them as being mosfets??
I suppose as long as they do the job.
They are looking good as they can run at 12v Vcc.
They could do the job, thanks for the info.
Also looking at CD4066 analogue switch, but I think that's out the window, as too much 'contact' resistance.
ci139
Joined Jul 11, 2016
2,037
how about your actual timing requirements - a simple resistive divider might be an option if the timing is not too critical
+ it likely also involves the available system/PCB space and power consumption we need to be considering ??
↑ the most viable solution is dependent on above ↑
ElectricSpidey
Joined Dec 2, 2017
3,362
I have no idea where you would be getting such information, these chips use DMOS.
panic mode
Joined Oct 10, 2011
5,420
does not need to be a mosfet, any transistor or IC with open collector or open drain will do. speed does not matter either since this is a replacement for manually activated buttons so any semiconductor will be faster.any 74xx07 will do, or ULN2003, ULN2083, tpic2701...
ci139
Joined Jul 11, 2016
2,037
sounds like a useful reference on your gizmo
https://forum.arduino.cc/t/xy-v17b-mp3-sd-card-reader-warning/550832
? 3.3V TTL input ?
a note -- the 5V TTL SN7400 input is at threshold when you shunt it to the GND with 1.8kΩ to 2.4kΩ resistor meaning @ 1.28V INP
to force its OUTP to valid logic HIGH took some (i don't remember) . . . say 10% of 5V = 0.5V → fuzzy estimate 581Ω to 775Ω !BUT! it's for the 7400 series
(speculating) . . . meaning -- if you pull about 1mA from your input it should activate it ???
the 2n3904 ver. above can be fit for 2N2222 matrix https://www.tti.com/content/dam/ttiinc/manufacturers/tt-electronics/PDF/MCABT8E2222C6.pdf or SMD-s
https://assets.nexperia.com/documents/data-sheet/MMBT3904.pdf
