Identify component
cstroh
Joined Jan 16, 2019
111
Need help in identifying the component. The label on the component is F at the top, the next line is RX10F and the last line is 65CB. The identifying label on the board is PTC1. The part looks like a 2 lead capacitor but other capacitors on the board are labeled with a C. Any ideas?
MaxHeadRoom
Joined Jul 18, 2013
30,808
As the board is marked PTC (positive temperatre coefficent) device, that ID's it.
The component looks OK, what is the need for the ID?
Max.
cstroh
Joined Jan 16, 2019
111
Just learning about the circuit. What is the function of a "positive temperature coefficient device". Is it a resister type fuse or a capacitor type fuse or what? Thanks for the reply.
cstroh
Joined Jan 16, 2019
111
AlbertHall, I was unable to open the datasheet you sent. Does this thing have an automatic reset internal cause nothing shows from the outside.?
cstroh
Joined Jan 16, 2019
111
Thanks to everyone. Guess I have a lot to learn about electronics and you have been a big help. Thanks again.
