Identify component on Power Board
isetlg
Joined Jan 12, 2024
12
Hi all, still doing sone tests, will be posting my findings on the weekend,
Hello Wandering 909
The next time i have the board out, i will try to get the part number on D72, the board is covered with this varnish, so i need to scrape it off maybe i'll be able to see the number.
I have to redo all the test in the Esab repair manual, then i will pull it out. Probably on the weekend.
I will also be posting my results.
Q6-IGBT-STGW60V60DF-i have replaced it for a new one, i was sure it was the problem, since it leads to Q26, no joy!
isetlg
Joined Jan 12, 2024
12
Thanks. I think its more likely to be an NDD03N60ZT4G (hence the 3N as well as 60ZG, T4 being the DPAK case variant.)
But there's likely to be other parts faulty on board. These things don't fail for no reason.
Hello Irving
NDD03N60ZT4G Obsolete
This product is no longer manufactured.
i was thinking maybe
FDD5N60NZTM
MOSFET N-CH 600V 4A DPAK
Irving
Joined Jan 30, 2016
5,195
FDD5N60NZTM
I'd say that's a reasonable alternate. Switching times are quoted as a bit slower but at a higher gate resistance (25 ohm v 5ohm). For this application I don't think thats an issue.
isetlg
Joined Jan 12, 2024
12
Well i would be very surprised if it powers up. As you say, there is most probably something else that blew.
I removed and checked the 4 500v470ufm capacitors, they are good. Unplugged all wire to the BR1 and BR2 rectifiers, checked all good. Replaced IGBT to Q6, still no change. Maybe another IGBT ? 1 of the 2 10k resistors gets a little warmer or hot when i leave the power on, 50 - 60 deg. cel. vs 20 for the other. Led 44 does not flash as indicated in the manual. Hoping to find the trouble soon. Thanks for the help
isetlg
Joined Jan 12, 2024
12
Hello, so i removed the 2 10k resitors and put 2 new ones, both the old ones are good i think, test reading = 9800 and 9810 but i may have broken the trace, see pics, my bad, i must be more careful.
Now they are at same temperature - + 1 deg.
re NDD03N60ZT4G is Obsolete and no longer manufactured.
3 AVAILABLE SUBSTITUTES:
https://www.digikey.ca/en/cross-reference?search=NDD03N60ZT4G
What do you think is best ?
