Ideas for lighting this meter?
spinnaker
Joined Oct 29, 2009
7,830
Building an analog meter clock. I have some of these retro metere.
They are not lite and I need soe ideas on how I might light them.
I tried a standard LED behind the plate but it was useless. I swear I had a whole bag of bright whites once but I think they ran off somewhere. Don't know if a bright white would do any better.
Lyonspride
Joined Jan 6, 2014
137
I think I'd be tempted to paint the back of the dial with clear UV reactive paint and put some UV leds behind it.... You should get an even matt green/yellow effect, it'll either look cool or it'll look crappy.
Alec_t
Joined Sep 17, 2013
15,149
1) Make the dial from clear plastic, engrave the scale/markings on the plastic, edge light the dial with SMD LEDs?
2) Make the dial from electro-luminescent sheet.
strantor
Joined Oct 3, 2010
6,875
Take the scale out
scan it
print it on plain paper
cut it out
stick it to a thin sheet of plastic
cut the plastic out
place the new cutout plastic+paper scale in place of the old one
put an led behind the scale
spinnaker
Joined Oct 29, 2009
7,830
cmartinez
Joined Jan 17, 2007
8,840
KL7AJ
Joined Nov 4, 2008
2,229
I would think a couple of LED's just below the movement would work.
For the proper vintage look I think you'd want a mix of green and yellow.
spinnaker
Joined Oct 29, 2009
7,830
If you can't find it, you can print in reverse on a sliced-open laminator pouch then iron that on to the lexan.
I found 67# vellum WAY more sheets than I need but they have it here locally. And adhesive transparencies do exist. I had some in my hands but the line was so long I figured I would pick it up when I pick up the vellum. All they had was light weight vellum in the store I was in.
