HiThanks
I can see the original 4069 circuit here.....................
I have the Library CD4000_v.lib.
From your demo the duty cycle is tiny.
How can this be increased in this circuit?
Instead of trying to make us feel guilty about how we discuss things, why not ask for clarification on whatever part is troubling you. If you're not getting anything at all out of any of these answers, you may want to take a few steps back and build some more fundamentals before trying to simulate integrated circuits. However, I suspect that's not the case, and that you're exaggerating and being a little dramatic.Thanks to all
Primarily I am here to learn.
I have a story.
20 years ago I went to the Hanoi university to learn Vietnamese.
For white devils, like myself, this is very very difficult.
After a lot of hard study I realized that the only Vietnamese people that could understand what I spoke were Vietnamese people that spoke English. Extremely useful NOT!
I see an analogy with this forum.
When a novice asks a questions the experts here have no real idea of the position of ignorance the novice is speaking from.
The answers provided tend to be "club speak" ie expert to expert. The poor old novice is drowned in unfamiliarity and alien terms.
I understand that the quality of the answer is determined by the clarity of the question.
But when you don't speak the language how can one ask precise questions.
The secrets to learning are persistence and paying attention, and in a venue such as this one that can certainly work. But sometimes there is a need to restate the question. I have asked that in a number of instances, requesting a better explanation of just what the original poster was seeking to discover. Your question was valid, as was my answer, but it did not fit your question.Thanks to all
I have a story.
Unfortunately, often true; but not always. And usually when a thread starts to wander off, the TS (that's you) can gently ask people to get back to his level. The good people do, the rest you can ignore. There is a frequent poster in another forum who regularly tells less experienced people to come back in twenty years and they might understand his answers. This forum has less of that attitude than most, so hang in and keep asking.When a novice asks a questions the experts here have no real idea of the position of ignorance the novice is speaking from.
Maybe not major but certainly significant.My variant on your theme FAILED. I obviously missed something major.
I have done this and made another correction.Maybe not major but certainly significant.
Change the 0.22pF (tiny) caps to 22pF as in the original.
You don't need the .param statement since you put all the pulse parameters directly into the pulse statement.Missing .param statement.
LTSpice has a steep learning curve (at least it's felt that way to me) and can be frustrating at times, but the payoff is well worth the effort. It sounds like you're making progress. Keep up the good work!I have done this and made another correction.
It now has life.
If the remaining neurones can continue working as a team I maybe able to massage it to where I need it.
Sorry for chiming in since I cannot reply but to the most basic of your question. I am afraid your are creating a problem of what is just what happens everywhere in life.Thanks to all
I have a story.
Yes...I make it a habit of using some resistance in voltage sources because in reality all voltage sources have some resistance.Thanks, I have had a go at this.
I did not copy exactly so I did not use "user defined" parameters in V1.
I could not understand your "Rser=100m"
Those represent the IC power supply connections. I showed them because they were on the original drawing.I am still confused with the two wires going into U1F despite no obvious connection points there.
I think the only thing you missed was the capacitor sizes. Should have been 22 pico farad instead of 22 femto farad.My variant on your theme FAILED. I obviously missed something major.
What is challenging is that mostly the actual circuit in logic gates is fairly complex, and mostly what one would find is a whole lot of circuitry that may vary between different manufacturers for the same IC.number. Most of the time that makes no difference, but in one instance I did a design that would work with National brand CD4538BE devices but was totally unreliable with Motorola "equivalent" devices. At least I think those were the two brands. My whole point is that the insides of even just an inverter are not trivial, and if you move to a schmidt trigger inverter the internal circuit is a bit confusing. So because the power supply normally does not connect directly to inputs or outputs it is simply understood to somehow supply the charges that they deliver and consume. If you can get hold of some 1972 or73 CMOS logic device manuals you will be able to see the circuits and what I was referencing.
And I hope that this long drawn out explanation has delivered a little bit of value.
