confusing schematics
alitronic
Joined Jun 13, 2020
71
Hello, I am a bit confused about this schematic;
In the first part, you can see the signal called ACD-DROP which should be later processed by a microcontroller, but in the microcontroller part of the schematic, the same signal is considered as an output. An explanation, please.
drjohsmith
Joined Dec 13, 2021
1,661
why do you say the micro is an output ?
in general the diamond symbol is just a picture , you need to look at the proc and see if thats an input or not
also check what type of logic the 4093 is, is it totem pole or open collector or what ?
ronsimpson
Joined Oct 7, 2019
4,841
Most (not all) micro pins have many functions. It can be programmed to be input or output and, in some cases, it can have different functions.
alitronic
Joined Jun 13, 2020
71
But usually when the arrow is oriented to the pic, it is considered as in input and when is oriented away it is considered an output.
drjohsmith
Joined Dec 13, 2021
1,661
the word is usual,
the better ( Imho) cad packages have different symbols, and enforce / warn. other , it seems like this have multiple but dont enforce .
at end of of day , conection with flattered cad is made by net name ,
are you wanting us to grade the schematic out of ten or just concerned by being puzzled ?
rsjsouza
Joined Apr 21, 2014
430
As others have said, the direction of the arrow depends on the CAD package or perhaps a convention chosen by the designer.
If your expectation was aligned with the designer (or the CAD package), the SDATA signal is bidirectional but the arrow points away from the microcontroller.
However, there is another signal where the arrow points towards the microcontroller - it is not clear what this signal is, but indeed the convention here can be very confusing.
alitronic
Joined Jun 13, 2020
71
The second signal is called "shutdown"
