Advices for these power supply schematics
jm-X
Joined Feb 12, 2023
36
Hi all,
Before wasting time and money, would you kind enough to check some schematics found on websites?
For 0-12 V Variable power supply, D3 and D4 are not the best way.
Better with a CT transformer and negative to get -1.24V0-15V-3A-Power-Supply.png
Thanks a lot, and nice day.
jmPower-Supply_0-20-1A.pngCS 9012
dl324
Joined Mar 30, 2015
18,502
You're right. Putting diodes on the output of the voltage regulator is a lame idea. You no longer have a regulated output voltage because it depends on the current through the diodes.
The second schematic doesn't have very good voltage regulation either.
38,932
Below is the LTspice of one way to get an LM317 (or LM350) to adjust to zero volts with good output regulation without requiring a CT transformer:
It uses a capacitor/diode voltage-doubler type circuit to generate a negative voltage, which is regulated to -1.25V by the inexpensive LM337 to offset the +1.25V minimum output of the LM317.
The LM337 can be a small package version since it only has to supply about 10mA of current.
jm-X
Joined Feb 12, 2023
36
Hi AAC members and Schmitt Trigger, Ron Simpson, dl324, Crutschow
Thanks a lot for your advices.
Always a pleasure to learn with your replies.
Nice day.
jm
jm-X
Joined Feb 12, 2023
36
Nice day.
jm
Hi Crutschow,
One more time, thanks alot :::))).
I need an output of 2A to be comfortable with the device.
Good choice i think.
Nice day.
jm
jm-X
Joined Feb 12, 2023
36
keep in mind that LM350 must have a large heatsink. without it IC will shut down due to thermal limit.
Hi panic mode,
Thanks for your advice.
Now, i get strong advices to get a '' bullet-proof '', an reliable PSU.
Going to compute thermal calculations about Heatsinks; i have a lot of docs about them - and like it - :).
Nice day.
jm
panic mode
Joined Oct 10, 2011
5,439
your regulator Pd is about 25-30W depending on package and manufacturer. some may claim 80+W but that will not work without cryochamber ;)
jm-X
Joined Feb 12, 2023
36
Hi Schmitt Trigger and Crutschow,
Sadly, you are right :::::(((((((
I made briefly some calculus with a spreasheet.
So, i think if you told me to ride to Pluto, it was a good reason!!!!
Would you kind enough to check if i made mistake(s) or ?
I put a 40°C in Ambient Temperature, and bad idea of course......
With a fan, is it possible to have an LM350 delivering 2 A, not more?
Found some heat sinks but bulky.
Another answer is to immerse the whole thing in Mediterranean Sea ::::::)))))))) closer than Pluto.
Thanks a lot and nice day.
jm
38,932
The make heatsinks with built-in fans ( as typically used for computer processor cooling) which can dissipate a significant amount of heat with a relatively small size.
You might look at using one of those.
schmitt trigger
Joined Jul 12, 2010
2,280
The bottom line is that you cannot realistically have that extra wide input to output ratio with a linear regulator. You will have to consider an additional switchmode stage somewhere.
I would attempt a linear to drop 800 to 380V, followed by the switch mode for the 380 to 12V conversion.
Having said that, for the first stage finding a series pass transistor with that much SOA, will be a significant challenge.
jm-X
Joined Feb 12, 2023
36
Hi ,
Thanks a lot.
Nice evening.
jm
jm-X
Joined Feb 12, 2023
36
Thanks also for your fast reply.
Nice evening.
jm
