Hi, I've been using this soldering station for 5 years and it's been my first decent soldering station I've ever had. I am really happy with it but after a few years, a lot of practice and repairs and use, I've developed some taste and noticed a few flaws or things I'd like to improve.
It has these specs:
- 58W power
- Temperature knob from 150ºC to 450ºC
- ON/OFF switch
I really like that it is a "powerful" 58W station, that can go from 150ºC up to 450ºC, but I've noticed that most of today's soldering irons are rated 60W or even more, so no problem here. I like also the ON/OFF switch and I normally use between 250-350ºC, or that's the range the knob marks, who knows what the reality really is.
Now the important stuff, things I don't like or hate, that I would like the new soldering iron/station not to have:
1. The cable is quite sturdy and thick, not flexible, and it's not that comfortable to use, specially when I have to put the iron in angle as not always everything is spacious and clean. Also, the cable is plastic, that I have accidentally touched over the years with the iron and it has some heavy marks or melted plastic. The cable should have a coating (heat resistant cloth?) that resists heat, ideally.
2. The tips are not standard and I really hate that, indeed it is the main reason I'm upgrading it. So it must be compatible with aftermarket tips
3. The mechanism to hold the tip is not very well made, as you slide the tip in and then screw a piece to hold it. When the soldering iron heats up or cools down, the screw "gets slightly loose" and the tip rattles a bit, really hate that.
4. The station is quite "big", I mean, it occupies a lot of space with the cable and stuff considering its small size. I don't like object that you can't save in a nice rectangular shape (reason why I bought a DMM case so it does not have cables hanging and flying around)
So the new one should have a flexible not too thick cable, have a knob or something to vary its temperature from a wide range (if it displays the temp digitally it would be so cool), be compatible with standard soldering tips so I can buy a bunch of different shapes and can select quality ones, and of course the mechanism that holds the tip should be well designed so the tip does not rattle. Ideally a separate structure for the holder, that way it's easier to clean the sponge.
About the price, I don't know, I'd really like to buy from a known electronic brand, but $120 for example would be too much, I was thinking about $50 or so, may be a little higher if it's worth it.
May be something like this, and I have heard about Hakko, but that's $100, a bit higher than expected:
Actually I don't really like that button layout, a knob looks way faster and comfy.
It has these specs:
- 58W power
- ON/OFF switch
