bassbindevil
- Joined Jan 23, 2014
- 828
I'm pleased with the Hakko T12 compatible station I put together from a kit for about $25. I was prepared to buy real Hakko tips for them, but the clone tips seem good enough. I normally run it from a 19V power brick, but it works OK from a 12V battery. The kit included a decent handle and a real silicone cable. The only real problem is that the board isn't correctly calibrated for the thermocouples in the T12 tips, so the numbers are really just relative temperature (but it is regulated) . I just set it to a number that works, until I can get my hands on a soldering iron tip thermometer.
https://www.banggood.com/STC-T12-DIY-Digital-Soldering-Iron-Station-Temperature-Controller-Board-Kit-for-HAKKO-T12-T2-Handle-p-1155034.html
update: that's not the same kit I got; mine included the handpiece, cable and tip; it's not showing at Banggood.com any more.
https://www.banggood.com/STC-T12-Di...s-for-HAKKO-T12-Soldering-Iron-p-1146578.html
This looks exactly like it, and is currently less than $17 Canadian including shipping:
https://www.aliexpress.com/item/4000577553855.html
By the way, the reason it comes with two tilt sensors is so you can mount them back-to-back (69 style) which makes the motion sensing more sensitive.
I got this self-contained T12 iron last year (it was about $10 cheaper at the time); you can find an updated version (with better controls and user interface) on ebay. It's more convenient for portable or travel use (one less box and cable).
https://www.banggood.com/75W-Mini-E...-Soldering-Iron-DIY-Handle-Kit-p-1754495.html
