You'll need to cut it open. You can use a hobby knife (Xacto) or whatever. When they molded it, it was easier to leave a very thin section rather than a hole.But the slot, as you can see, is not a hole. You can's pass the tab through it.
Looks neat and clean, no point to point wiring. Nice external fuse.Here are some photos of the insides, by the way:
Oh, now I finally get it. Yeah, the fact that there were no hole completely confused me. If I had saw a hole I would have guessed its purpose.You'll need to cut it open. You can use a hobby knife (Xacto) or whatever. When they molded it, it was easier to leave a very thin section rather than a hole.
For calibration, I think it is worth picking up one of the many Hakko 191 clones and doing it right. The price on AliXpress is not better, in fact some cost more.Okay, now I have a lot of questions regarding the settings:
1. The first setting is CALIBRATION, and I don't have any fancy precise temp meter, so I don't know how should I calibrate.
I am a big fan of reading the datasheet for the solder and following the manufacturer's numbers.2. What are the recommended shortcut temps?
By default these are 200, 350 and 450 ºC. I guess 350ºC is for standard solder. I use a Pb38, Sn60 and Cu2.
I have surely worked on RoHS boards and devices, but, to start with, I didn't know that it meant "Pb free device", and I always used regular solder as I just described. Is that wrong?
I mean, the amount of my solder in the reparation must be so little compared to the solder Pb-free used in the whole board.
If you find the wait tolerable, there's nothing wrong with that. The tip will last indefinitely at that temperature, even if you accidentally leave it on overnight.3. The autoidle and autosleep, I want them as low as possible to waste the least amount of energy when working. I have set idle to 80ºC in 1min and sleep in 2 min. Knowing that the iron is ready in 4-5 seconds, I guess these times are fine, right?
Usually, it would be for soldering to copper floods and large components that act as heatsinks and make it very hard to heat the joint sufficiently.4. The temp boost is +50ºC, and I think it is used to melt some "old, hard to melt" solder when desoldering, right?
Flux on the tip is no problem. Clean it with the bronze wool after each joint to get rid of the excess flux for soldering purposes. I usually put some solder on the tip if I know I am turning it off as a sort of protection, but that's additional and not required.5. Also, regarding tip maintenance, I always, when I've finished, clean the tip with the copper/brass mesh, which normally has some flux residue (although my flux is non corrosive and non conductive). Is that OK? Or that scrapes the tinning of the tip and exposes the nude tip, which can go black and oxidize? Should I add new solder instead?
Your great results are gratifying. I have been recommending the variants of that station for a while and for whatever reason people don’t buy it. I think it is because the price is so low you don’t know what it really is. The often end up getting something like the Hakko FX-888D which is a great station and a workhorse but uses conventional tips and is big and heavy.Yaakov, today I officially used it to repair some headphones, tiny cables, a bunch of stuff in different devices...
Jesus oh Lord our savior, hahahaha, the difference when working with such a beast precise machine like this one is abysmal. The fact that in 5 seconds I already have the 350°C is so, so, so comfortable and very efficient with my time and specially with the energy. Before I had to wait MINUTES, now you are a soldering machine! BAM, ready to work. Absolutely incredible.
Also I've never worked with such tiny and precise tips, my God, it is just another whole game to work with this station, me that I work a lot with tiny stuff, wow, the tips are miraculous. Until now I had to play with the flux to avoid bridges, had to rotate the giant comical tips, the solder never stuck where I wanted exactly...
I don't know what I've been doing all these years, what a quantum leap! I thank you once again for recommending me this station, you made my year!
Thanks for all the info, but I am not sure if that applies to the one I bought, neither I am sure I understood all that data you shared. What kind of measurements do you want me to perform on my station?KSGER T12 soldering stations they changed the power supply so the 24VDC(-) side is floating, it's not earth grounded.
V2.04 (green) was PE grounded, V2.05 (black) is not. This is a problem.
You can verify with an ohmmeter or measure ACV at the heater shell/tip between PE ground. A tip floating at 60VAC due to the Y-capacitor is bad for soldering components and since these PSU's have no safety certifications whatsoever, the transformer quality can be poor as far as pri-sec insulation and high risk. On other T12 clones PSU board there can be many spacings violations as well.
For safety, PE ground the secondary side at the controller board or jumper it on the PSU board. The enclosure also should be grounded as well.
Also the fuse(s) are oversized at 5A, the power supply will generally blow up many parts before the fuse blows.
View attachment 264736View attachment 264737View attachment 264738View attachment 264739View attachment 264740View attachment 264741View attachment 264742
I have the 120VAC version of this and I'm happy with it.Ideally I want to buy a good one, one heatgun that lets me select the temperature precisely, nicely built, etc...
Thanks!I have the 120VAC version of this and I'm happy with it.
https://toolboom.com/en/lead-free-hot-air-soldering-station-aoyue-2702aplus-220-v/
I've never used the soldering iron because I don't like the tips and it's too bulky. The desoldering tool is handy.
I don't see that as a problem. I have 4 Weller soldering stations; 5 if I count the military version I got my Wife for doing stained glass. I put my Weller W-TCP on top of the Aoyue.notice I already have one soldering station
The heating element is in the metal part of the hot air tool.Does the air from the heat gun come from the station or the very same handle is what takes air from the back and blows it forward?
Yeah, but I meant the air that the gun blows. Does it come from the station through a pipe or tube that goes to the gun, or the gun takes it from its back?I don't see that as a problem. I have 4 Weller soldering stations; 5 if I count the military version I got my Wife for doing stained glass. I put my Weller W-TCP on top of the Aoyue.
The air comes from the tube connected to the back of the wand.Yeah, but I meant the air that the gun blows. Does it come from the station through a pipe or tube that goes to the gun, or the gun takes it from its back?
You can move the soldering station you're not using... Most of my bench is covered with equipment, tools, and storage. I only have a couple square feet of workspace and I don't find that to be a problem.The problem is space. My workbench and tool space is quite full now I wouldn't want another bulky station, that's why I am wishing I could plug a heatgun to my T12-X station.
Thread starter | Similar threads | Forum | Replies | Date |
N | Linear PSU upgrade | Power Electronics | 9 | |
treadmill motor upgrade | General Electronics Chat | 7 | ||
Bose QuietComfort 15 upgrade, battery noise | General Electronics Chat | 3 | ||
B | DSO138 Firmware and Hardware upgrade | Test & Measurement | 6 | |
D | Soldering problem - upgrade.... but to what? | General Electronics Chat | 43 |
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Duane Benson
