I need some help with my assignment, because i am not an expert...
alright212
Joined Apr 17, 2022
Basically assignment was to create a counter using JK triggers and the 7 segment display should count down from 13(d) to 0. Problem i am facing with is that i made this scheme with parallel transmission, but i need to have sequential transmission. Can you help me with that? Also if i press reset then it shows "0" but it should show "d".
dl324
Joined Mar 30, 2015
18,460
Welcome to AAC!
Tell us what the circuit is doing wrong.
I have never heard of parallel or serial transmission. Can you post a reference to the definition?
Where is the reset button? Your flip flops don't have a set or reset input.
It would be helpful if you posted the complete text for the problem. Translate if necessary.
EDIT: Please clarify the connections circled in red.
Unnecessary wire jogs make your schematic more difficult to read.
It would helpful if you also posted your truth table and kmaps.
