i need help with MicroWave Transformer
dhawkins263
Joined Feb 1, 2018
13
how about if you connect them with the first one being hocked up to 120 volts ac and the output of that one being hocked up to the input of your second transformer
dhawkins263
Joined Feb 1, 2018
13
well im trying to step up the power by connecting two unmodified transformer together ,120vac to transformer #1input the transformer #1 output to transformer #2's input hoping to get double the power. Is this achievable? or will this melt,explode,or kill me?
AlbertHall
Joined Jun 4, 2014
12,660
It won't double the power (power = voltage x current).
Are these modified or unmodified transformers? If they unmodified then, no, it definitely won't work and something's going to smoke.
Colin55
Joined Aug 27, 2015
519
This type of transformer only works when it is fully loaded.
You can parallel or series them provided you connect them to a load.
The load may be anywhere between 600 watts and 1200 watts
-live wire-
Joined Dec 22, 2017
959
It is impossible to just step up the power. You can get bursts of higher power, high voltage and lower current, or lower voltage and higher current. Pout < Pin.
