Someone on here altered it for me but I can't remember who. Would making darlington pairs with tip increase their gain? I'll probably tinker around. If they aren't suitable for audio amplification I'm sure I can do something else with them.
Honestly I bought them for the price point/amount. Thinking about it I could likely salvage better ones. I did manage to salvage a couple of opamps that I didn't know I had and I'll just buy some decent ones. I want a good audio amp so I'll have to pay for good parts.It is crazy to use low power low current transistors in a power amplifier.
Current gain yes, voltage gain no. But a pair of darlingtons have twice the voltage loss as compound transistors so use compound transistors instead.Would making darlington pairs with tip increase their gain?
What do you use to simulate with? If I had something like that it would help me alot. Getting to see results before wasting hours building one that won't work seems pretty enticing.My simulation shows an idle current of the entire amplifier of 6mA and only 2.6mA for the output transistors which is why there is a little crossover distortion.
So they can work. TIP's are fine if driven by a different transistor. A guess but tip's in an AB class need a better driver in the schematic I posted? Or does it need a little more complexity than just 3 transistors(which is just fine with me)?Current gain yes, voltage gain no. But a pair of darlingtons have twice the voltage loss as compound transistors so use compound transistors instead.
The input transistor of a Darlington or compound transistor conducts only a medium current so a power transistor like a TIP is not needed.
A 2N4401 and 2N4403 little transistor would be fine to drive the TIP output transistors.
Me and most of us use the free LTspice XVII simulation program available at Lin... (OOPS, they were bought) Analog Devices.Awh
Many members here use LTspice, a free download from Analog Devices. There is a Yahoo LTspice User Group which has additional free models.What do you use to simulate with?
Ahhh. Yes that's only available in pc version I believe.Me and most of us use the free LTspice XVII simulation program available at Lin... (OOPS, they were bought) Analog Devices.
It seems I'll have to drag my pc out of storage. I don't use it very often.Many members here use LTspice, a free download from Analog Devices. There is a Yahoo LTspice User Group which has additional free models.
Edit: AG beat me to it![]()
Sure I agree! The TS posted the original circuit, I was just curious if it would actually work.It is crazy to use low power low current transistors in a power amplifier.
Sometimes those simulations don't agree with the real thing. There's always some variation in the components used. All I tell you is what I measured. I'll double check the circuit again.My simulation shows an idle current of the entire amplifier of 6mA and only 2.6mA for the output transistors which is why there is a little crossover distortion
I suppose.The sim program uses "typical" transistor spec's
I did try one very similar to ltspice but you only get to test one circuit once then it's a monthly subscription. They do exist but the only ones that work I can't afford.Do people do simulations on a Fone?
I'm not upset about it. I'll just buy ics meant for what I'm aiming for then I'll experiment with bjts until I make something comparable to what I want. Just to learn more. I am learning more and more but I think it's my components are the problem so I'm not getting results I'm being told I should or that I'm expecting.Sometimes those simulations don't agree with the real thing. There's always some variation in the components used. All I tell you is what I measured. I'll double check the circuit again.
SG
So what exactly are the transistors you have on hand?I think it's my components are the problem so I'm not getting results I'm being told I should or that I'm expecting.
