- Joined Jan 23, 2018
- 27,906
Those complete amplifier IC devices can certainly be very useful, but because they have a lot of gain and also quite high frequency response there is a potential for instability if the circuit layout is not right. Any excess resistance or inductance in the "grounds" part of the circuit can result in coupling that leads to instability. So if the maker shows a PC layout for the device you should consider copying it, or at least understanding what it implies.
The 2N4401 and 2N4403 are indeed better choices, also because they are lower noise devices. So in circuits where noise matters they are worth the extra cost. For DC and digital control work the 2N3904 and 2N3906 are fine. I use them frequently.
