panic mode
- Joined Oct 10, 2011
- 5,093
and what is wrong with that? ever used current source?It matters when people don't truly understand whats going on!
I have seen it FAR to many times where people think that you can make current (i.e. supply current which produces a voltage).
thinking that current is result of voltage can also be misleading....
so what is equation for calculating voltage drop? V=IR
and if you do anything analog (either power or opamps) voltage drop is everywhere.
where is voltage source when you have emission of ions? (radiation)
how do you explain chemical batteries?
how do you explain boost converters (SMPS), eddy current and more?
