I need help,AC/AC power transformer,please take time and read...
Masimo
Joined Jan 2, 2017
7
I need some help,and i hope you will understand what is bothering me.I apologize up front for my English,and for dumb questions i will probably ask you here.So,i built Objective 2 by NwAvGuy headphone amplifier from scratch(more info here http://nwavguy.blogspot.hr/2011/07/o2-headphone-amp.html),and this amplifier requires to be powered from AC source,it will not work if power it with DC supply.I can't find where to buy AC/AC wall transformer with EU plug(or it is too expensive).On datasheet for this amplifier it says AC power supply can be used if it is in range 14VAC-20VAC and minimum current should be 200mA(info from website
"The Objective2 accepts the following power adapter characteristics:
Type: AC-to-AC Transformer (AC/AC, not AC/DC!)
Voltage: 14VAC minimum, 20VAC maximum
Current: 200mA minimum, no maximum
Plug Size: 2.1 x 5.5mm (Inner Diameter x Outer Diameter) )
Since i can't find where to buy it I was planing to use things i already have.I have 120VA toroidal transformer,Primary winding requires 230V AC(from wall outlet) and secondary winding outputs 20V AC with maximum current of 6A,(6Ax20V=120VA(W) transformer).
NOW my question is can use this transformer to power up my amplifier.I was thinking to connect power cord to primary winding(and to wall outlet) and to connect secondary winding to AC input on amplifier.I don't want to burn my AMP because i am dumb.
I am electrotechnician,finished 4 years of school and i still don't know will transformer send 6A to my AMP and smoke it,or will AC devices take only the current it requires.
I believe this will work,but i want someone to confirm it.Common sense tells me if for example i connect light bulb to 200V,and it is 100W bulb it will draw 0.5A of current(W=U*I) because that is preset with bulbs input resistance(lets say 100 Ohm)...so following Ohm's law I=U/R i concluded input voltage and input resistance determine what Amperage will device draw from source.So if i am right input voltage and input resistance of my amplifier will control what current will amp draw in order to operate.
Dodgydave
Joined Jun 22, 2012
11,395
The link doesn't work!!!!
Have you got a circuit diagram?
If your circuit needs AC 14-20V @200mA, then your 20V transformer will work ok,
Masimo
Joined Jan 2, 2017
7
working link!!!
I came to conclusion i can't use that transformer because it outputs 20V only when outputing max current(close to 6A).My amplifier can work even on 200mA so that means transformer will have very low load on secondary coil and output much higher voltage(30-32V) and that would damage my amp.
