Need help troubleshooting a SOLA 24V Power Supply
ElectroTechy26
Joined Jan 28, 2026
I'm trying to troubleshoot why my SOLA 24V power supply won't output any DC voltage.
I see no burnt or scoreched marks on the board. I've check the fuse and all the electrolytic capacitors and I don't see any obliviously bad caps.
My next step is to check the MOSFETs and the large inductors that change the voltage from 120VAC to 24VDC. But I don't know how to check for bad MOSFETs or Inductors.
What else shouldn't checked that I'm missing?
Any help would be appreciated. Thanks.
panic mode
Joined Oct 10, 2011
5,444
the best you can do is identify IC or ICs on the board, read the datasheet and that should get you general idea of the circuit. then you can measure voltages and post results here to be compared to expected.
