I need curcuit 220v ac to 12v 3A output for my school project., help please
MaxHeadRoom
Joined Jul 18, 2013
30,876
DC or AC output?
Look for a Wall Wart, you may even find one at a re-cyclers if you have one near you.
Or 'borrow' one from a current piece of equipment.
Lap-tops are a possible source.
Max.
iamprincejoy
Joined Aug 7, 2017
25
DC or AC output?
Max.
9v or 12v Dc output, the current output is 3 to 5 ampere, I need a schematic diagram for the circuit because I explain it to my professor of how its work.
Definitely better to buy one (or recycle one) than build one - cheaper, safer, quicker, and more reliable.
Thank for the reply, I need the schematic diagram so that I can explain how its work.
T
bertus
Joined Apr 5, 2008
23,025
What did you learn about powersupplies upto now?
What have you done to solve the project?
Did you do any reseach?
Bertus
PS I moved the thread to homework help
WBahn
Joined Mar 31, 2012
33,316
You probably won't be able to get a schematic for the particular supply you find. There are lots of ways to make a supply with lots of different features. Linear supplies are the easiest to understand, but almost any supply you run across these days is going to be a switch-mode power supply, which are a lot more complicated.
How much detail are you expected to give?
jayanthd
Joined Jul 4, 2015
945
T
I can provide you a schematic diagram for both 12V DC output using Buck converter LM2576-12. A step down transformer is needed to step down 220V AC to 12V and this is rectified and fed to LM2576 Buck regulator which can provide max 3A output current.
Will this be sufficient ?
WBahn
Joined Mar 31, 2012
33,316
T
What is your actual assignment? To find a power supply for a project and then be able to explain how that particular supply works? Or to design and build a suitable power supply for your project and be able to describe how it works?
jayanthd
Joined Jul 4, 2015
945
Hi
If 12V 3A DC output is sufficient then you can use a 220V to 12V step down transformer and rectifier circuit with this module.
http://www.dx.com/p/lm2576hv-dc-dc-...NlIIJUdwPZVum9o1svgaArysEALw_wcB#.WZE_5VEjF9M
I was talking about this step dowm Buck regulator.
http://www.ti.com/lit/ds/symlink/lm2576.pdf
If you need 12V 5A DC output then I can make a Buck Power Supply using Microcontroller, PIC12F or 18F, Power Mosfet, inductor, capacitor. and a few additional components like IR21xx FET driver.
iamprincejoy
Joined Aug 7, 2017
25
Bertus
Thanks for the reply,
Maybe 9 or 12v and
3 to 5 amperes is what I need.
That can supply an audio amplifier.
From AC source to transformer to rectifier the current that pass trough that part what I need to know and the current that will supply the circuit and also the output current.
My professor said he wanted an combining IC and discrete in one circuit of power supply.
iamprincejoy
Joined Aug 7, 2017
25
Thank you for the reply sir,
That's ok sir 12v and 3A,
That my professor he wanted
iamprincejoy
Joined Aug 7, 2017
25
I needed A circuit proposal first then I explain it how its work, and if its approved by my professor, I will build it and prove that it is working.
I wanted a 9v or 12v and 3 to 5 amperes DC output, with Discrete and IC type combining in one circuit.
iamprincejoy
Joined Aug 7, 2017
25
Hi
Thank you very much, I hope you can make me for that.
WBahn
Joined Mar 31, 2012
33,316
You really should have included this information in your first post. Just think of all of the posts recommending that you get wall-warts and such that could have been avoided. Also, knowing that you need to include both discrete components and IC's narrows the possibilities as well. Furthermore, the fact that you need to build and demonstrate the supply in the schematic narrows the field to supplies that are relatively easy to construct for someone new to electronics.
The next question is whether you want it to be adjustable between 9V and 12 V? If not and if a fixed-voltage supply is adequate, then pick one.
You also need to pick a current capacity. Is 3 A enough, or do you need 5 A?
With all of that in mind, and given that 3 to 5 amperes is a significant, but not outrageous, amount of current, I would recommend using a circuit based on either an LM317 adjustable voltage regulator or a LM7809/LM7812 fixed voltage regulator. To get that kind of current, use a circuit that uses a bypass transistor (which will check of the box of needing to use discrete components nicely, since it's possible that capacitors/resistors/diodes and the like are not what that requirement had in mind).
Look at the data sheets for the IC's I mentioned. They generally contain several power supply circuits and sometimes decent explanations of how they work.
jayanthd
Joined Jul 4, 2015
945
I will provide the circuit. If you are a student then you can order LM2578HV-12 samples from TI.com
You need to buy one 100 uH 3A Toroidal Inductor. 2 electrolytic capacitors. 1 6A rectifier diode.
There is no LM2578HV-12 model in my schematic software. I will make the schematic only model and draw the circuit. I will post the circuit today.
WBahn
Joined Mar 31, 2012
33,316
@iamprincejoy: I would strongly recommend against just having someone provide you with a schematic and parts list, unless your goal is to learn little to nothing and possibly get a failing grade when you aren't able to adequately explain how your supply works, since that appears to be a key element of this assignment.
Wouldn't it be better if you could describe exactly what each component in your design does and how it does it and why that component was chosen?
