Hello, I have SMPS Meanwell RPS 200.
I have same problem as in video
I removed XY blue caps that connect one pin of L or N line to GND.
But the effect (lower but) still is there. If I rotate power cord pins then it's fine (as you see from video was glowing both directions before).
There is no Ground, so I want this not happen as appliance GND will be connected to PC.
