I can't determine capacitive and inductive resistance of the circuit.
michgkou
Joined Oct 3, 2019
43
Homework: Specify the currents and the voltage drop of the elements (pic attachment). The circuit is working for a sufficiently long time.
I'm trying to solve this but it becomes difficult. I'm using KCL and I repalce ZL = j0,1ω (Ω) , ZC=... etc.
Finding 3 equations with 3 unknown variables (plus the ω).
And now it's time for Cramer's rule.
I'm not sure if I should move on.
What do you say ? I'm on track ?
Thanks.
The Electrician
Joined Oct 9, 2007
2,986
I see 11 "elements"; how can you only have 3 unknowns? What method of solution are you using (mesh, nodal, branch, etc.)? For whichever it is, label the currents or nodes on the schematic. Show your equations. Is ω given a numerical value, or to be taken only as a symbolic variable.
michgkou
Joined Oct 3, 2019
43
Thanks for you answers!
By the way I solve'd it. The point is the "sufficiently long time" of the title. The inductor act like a wire an the current through the capacitor is zero.
