Hyestresis problem
TAKYMOUNIR
Joined Jun 23, 2008
352
32,840
Could you PLEASE, for ONCE, at least TRY to answer your own question and show SOME work, instead of expecting people here to be your no-effort-required-on-your-part answering service?
Dodgydave
Joined Jun 22, 2012
11,395
Well the voltage on pin 2 is 40 volts at 40Kv, and 2Volts at 2Kv, with the values of R4 & R5, so it will be 10Volts at 10Kv.
So it wont work!
TAKYMOUNIR
Joined Jun 23, 2008
352
Hi in this circuit i need my hestresis between 6 V and 1 so when vin is more than 6 v the vout will be low and when vin decrease and reach 1V vout will be high
so i did the calculation as following
i let R3=10K ohm
AND WHEN VIN REACH 6V I WILL HAVE
4v/R2+(15-6)v/R1=6v/10K ohm
AND WHEN VIN REACH ZERO
9v/R2-1v/R1=1v/10K ohm
AND I SOLVE THESE 2 EQUATION FOR GETTING R1 AND R2
MY QUESTION IS THIS TRUE AND IF I NEED MY HYSTRESIS FROM 6 VT 0V WHAT THE SECOND EQUATION WILL BE
32,840
i let R3=10K
4/R2+(15-6)/R1=6/10K
9/R2-1/R1=1/10K
Thank you for finally showing some work! (Next perhaps you can work on using a meaningful thread title).
You equations look good, other than you obviously don't believe in tracking your units, which I harped about more than once. If you want any assistance from me in the future, you better use your units.
Without a negative supply someplace, you can't get a threshold of 0V. Even if you could, you could have problems getting enough overdrive to ensure that it transitions.
TAKYMOUNIR
Joined Jun 23, 2008
352
is my calculations is true
spinnaker
Joined Oct 29, 2009
7,830
I think Wbahn wants you to rewrite it to, include units, to make the formula more readable. You need to do a better job at helping others to help you including providing as much information as possible and stop creating multiple threads on the same subject.
But these are common sense things that are common on almost any forum. They shouldn't need to be mentioned by other forum members, you should already know this.
TAKYMOUNIR
Joined Jun 23, 2008
352
i write the units
