Huskylens camera and Arduino
luger123
Joined May 18, 2023
12
I am a beginner and learning Arduino programming.
I'm designing an autonomous vehicle and I'm having some minor problems with it.
I use an LCD display and a Huskylens camera. Does anyone have experience with her? Can you advise?
luger123
Joined May 18, 2023
12
I would like to send data from the Huskylens (trucking object) and display it on the LCD. The IDE serial monitor shows the correct values (xcenter, ycenter .....) but the LCD shows the value "-1". LCD is I2C, Huskylens UART (RX,TX).
I think my code is correct.
Ya’akov
Joined Jan 27, 2019
10,258
This is confusing. Help me understand, You have an LCD display that is not the onion the Huskylens and you want to show the numerical data, as text, on a second display?
luger123
Joined May 18, 2023
12
Yes. I need to check the data while the robot car is driving (without cable).
The LCD display is 4x20 characters and works normally. It displays all other data correctly.
luger123
Joined May 18, 2023
12
Thank you for your interest in my problem.
Excerpt from the program code (the entire program code has 450 lines)
I can also send the full code.
C-like:
  #include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include "HUSKYLENS.h"
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
HUSKYLENS huskylens;
void setup() {
Serial.begin(115200);
mySerial.begin(9600);
  lcd.init();                      // inicializace LCD displeje
lcd.backlight();                 // zapnutí podsvícení displeje
//huskylens.writeAlgorithm(ALGORITHM_OBJECT_TRACKING);
void printResult(HUSKYLENSResult result);
void loop() {
  HUSKYLENSResult result = huskylens.read();
  int aaa=result.xCenter;
  lcd.setCursor(0,2);
  lcd.print("stred X: ");
  lcd.setCursor(9,2);
  lcd.print(aaa);
Ya’akov
Joined Jan 27, 2019
10,258
C-like:
void setup() {
void loop() {
  lcd.setCursor(0,2);
  lcd.setCursor(9,2);
  lcd.print(aaa);
When you say that the proper values appear via the serial monitor, do you mean when you print your variable aaa there, or something else?
luger123
Joined May 18, 2023
12
Oops, I didn't think of that. I have not tested the display value "aaa". But, in another part of the program code I control the motors and they don't respond.
For example:
else if(result.xCenter>=200)
right(); // engine
Result:
engine no action - (changing the value from 200 to any does not affect the result).
Ya’akov
Joined Jan 27, 2019
10,258
To debug this, you need to work out what the value of result.xCenter is. You will need to print it via the serial console to determine if it is returning what oyu expect.
luger123
Joined May 18, 2023
12
serial monitor output:
The values from the camera are ok. The serial monitor displays them correctly. I think the error is in the code program - conversion of values from "result.xcenter" to the correct value to be displayed on the LCD. But I'm just guessing.
Ya’akov
Joined Jan 27, 2019
10,258
You are printing using a function I can’t see. You are not just using Serial.println() to print the variable you are trying to use.
luger123
Joined May 18, 2023
12
Code for output to the serial monitor:
void printResult(HUSKYLENSResult result){
if (result.command == COMMAND_RETURN_BLOCK){
Serial.println(String()+F("Block:xCenter=")+result.xCenter+F(",yCenter=")+result.yCenter+F(",width=")+result.width+F(",height=")+result.height+F(",ID=")+result.ID);
delay(1);
else if (result.command == COMMAND_RETURN_ARROW){
Serial.println(String()+F("Arrow:xOrigin=")+result.xOrigin+F(",yOrigin=")+result.yOrigin+F(",xTarget=")+result.xTarget+F(",yTarget=")+result.yTarget+F(",ID=")+result.ID);
delay(1);
else{
Serial.println("Object unknown!");
delay(2);
Print on the LCD display:
//------------------- souradnice objektu -------------------------------------------
lcd.setCursor(0,2);
lcd.setCursor(9,2);
lcd.print(aaa);
lcd.setCursor(14,2);
lcd.print("Y: ");
lcd.setCursor(17,2);
lcd.print(result.yCenter);
Ya’akov
Joined Jan 27, 2019
10,258
Where is this from?
I can’t find anything like it in the API documentation, though there is a HUSKYLENSResult read()
It isn’t what the function that is working is doing.
Ya’akov
Joined Jan 27, 2019
10,258
Try putting your LCD code in here:
C++:
    // LCD code here, using result.xCenter
    else{
luger123
Joined May 18, 2023
12
I solved the problem with the data output to the LCD display. Thanks everyone for the advice.
But I have another question and I am asking for your advice. Is it possible to transfer an image (or video) from the Husky to a PC via Bluetooth?
