Hub motor controller
pjreijiri
Joined Aug 19, 2015
116
Hello everyone I am building a robot and I am using hub motors to drive it.
I attached a picture of the control circuit. I was wondering if you can take a look at it and let me know if it works and if it is possible to have the motor run in reverse or should I create another circuit that has the poles flipped and connected to the motor.
Regards,
Patrick
pjreijiri
Joined Aug 19, 2015
116
Hello guys, I have been looking for H-bridges and either they are very expensive modules or can support up to 5A.
So I decided to make a simplified version.
What do you think of this circuit. I used IRFP4468 MOSFETs with a 220ohm resistor bank connected to the PIC microcontroller.
I used 4 MOSFETs for each motor and I "turn on" 2 at a time to drive it forward or reverse. Also for the second motor I flipped the motor connector.
What do you think?
pjreijiri
Joined Aug 19, 2015
116
why do i need a whole circuit since the IRFP4468 can be run with a voltage of 2-4V? I am using a pic16 so the 3.3 volts should work
Am I wrong?
pjreijiri
Joined Aug 19, 2015
116
I need to be controlling the motors with a PWM so I can control the speed.
I tried using the MIC4451 to run the MOSFETs. Both MIC are connected to the PWM of the microcontroller and they will be on the whole time. However I will use npn junctions that are connected to the microntroller and they in turn will control which way the motor is turning.
Would that work?
Would connecting a transistor to the VDD of the MIC instead of the MOSFETs be a better idea?
Alec_t
Joined Sep 17, 2013
15,119
Would that work?
Not with the motor connections shown. What are the diodes for? The lower ones seem the wrong way round.
Alec_t
Joined Sep 17, 2013
15,119
Your circuit can't switch the upper FETs on. If you want to drive the motor with 48V then it needs ~58V on the upper FET gates to turn them on. That calls for a high-side FET driver IC such as the IR2110 which Max pointed out in post #7. The MIC4451 used in your circuit is a low-side driver only.
pjreijiri
Joined Aug 19, 2015
116
But would I be able to drive the IR2110 with a PWM from the PIC16? Because I want to set the speed of the motor
