HP 1725a Oscilloscope display is upside down
RF Fox
Joined May 23, 2018
9
It appears that my Oscilloscope display is flipped. I was testing with the oscilloscope music demos and saw-tooth waves and they are flipped. I do not see any controls for display orientation. How Can I fix this?
38,825
Measure a positive DC voltage (such as from a battery) with the oscilloscope.
The trace should go higher.
If so, then their's nothing wrong with you oscilloscope.
(Check to make sure there's not an inversion switch for the oscilloscope input.)
35,187
A photo of the symptom would be helpful.
Yes, some scopes have an INVERT option.
There is a B INVERT button on your scope.
