RichardO:You have something important missing from your circuit. That is power supply bypass capacitors. You should place a 10 uf cap from +9 volts to ground and another 10 uF cap from -9 volts to ground. Then on each 8038 you should also put a 0.1 uf ceramic cap from the +9v to ground and -9v to ground. The 0.1 uF caps must be installed as close as possible to the 8038 power pins with short leads going to ground.
All of these caps are needed. If you don't install them the 8038 will not generate clean waveforms. In addition, with more than one 8038, the oscillators will have a tendency to lock to each other trying to run at the same frequency.
The bipolar power supply that I'm using is this Craig Anderton design :
Are the 10 uf caps in this diagram what you're talking about, or should I use additional 10 uf electrolytic caps?
