how to use instrumentation amplifier AD620?
ahmedzaidan
Joined Jul 22, 2017
39
Hi
i need to amplify a signal from (0-5mv) using AD620 to (0-3V)?
how can i determine the gain and the reference voltage ?
thanks in advanced :)
ahmedzaidan
Joined Jul 22, 2017
39
so it is impossible to use single power supply !!o_O
is there other instrumentation amplifiers work with single power supply ?
i have tried v+=5,V-=-5 ,Vref=0.
it worked fine.. :)
i need to use microcontroller to read the the output of ad620 .
should i need to add other elements?or connect it directly?
ericgibbs
Joined Jan 29, 2010
21,521
hi a,
That is a half bridge, using passive resistors to make up the other half bridge into a full bridge, it is often configured in that way.
Do you have a AD623 or any regular OPA's that you could use for the amplifier.?
E
ahmedzaidan
Joined Jul 22, 2017
39
hi a,
i have AD620,LM358,LM324 and 741 ..
i will buy AD623 if needed :)
E
ahmedzaidan
Joined Jul 22, 2017
39
Hi ericgibbs,
thanks for your appreciated effort :)
can i build a dual power supply without using transformer and rectifier circuit ?
with single power supply it would be better to use ad623 instead of ad620+1m324?
^_^
