How to test a Ceramic Cap
bertus
Joined Apr 5, 2008
22,985
It is a safety capacitor.
Read this article:
https://www.allaboutcircuits.com/technical-articles/safety-capacitor-class-x-and-class-y-capacitors/
From the article:
If a Class-Y capacitor, also known as the "line to ground capacitor" or "the line bypass capacitor"—the capacitor placed between line and ground—fails short,
this could lead to a fatal electric shock due to the loss of the ground connection.
Class-Y safety capacitors are designed to fail open.
A failure will cause your electronic device to be subjected to the noise and interference that the capacitor would normally filter out,
but at least there will be no fatal electric shock hazard.
Bertus
ronsimpson
Joined Oct 7, 2019
4,774
A capacitor meter will probably read 2200pF. (more or less)
A ohm meter should read "open".
Meters measure at a very low voltage. This is a high voltage cap and probably should be tested for leaks at 100 volts or more.
Because of all the power parts in this part of the circuit, the caps need to be tested out of circuit. Pull one leg out of the board.
A shorted cap will measure near zero ohms even in circuit.
Often "Y" caps show damage if the are bad. These look good.
If these caps were removed your power supply will still function. So a open cap will not effect your circuit much. A shorted cap will pop the fuse.
