How to start debugging with MPLAB
Fanfire174
Joined Mar 13, 2018
240
I have a pickit 3 and I work with PIC 8-bit MCU's like PIC16F877A
IDE : MPLABX
Compiler: XC8
Language : C
I follow the following steps to program PIC Microcontroller
Project -> Double click on project Name
Build -> Run
Does anybody know the steps to debug code with MPLAB?
spinnaker
Joined Oct 29, 2009
7,830
IDE : MPLABX
Compiler: XC8
Language : C
Build -> Run
In MPLABX, I would need to go out on a limb and take a wild guess that you should click on Debug
Fanfire174
Joined Mar 13, 2018
240
there is debug option in MPLAB IDE
I can build and Run the code but I don't understand how to debug following example code ?
C:
// 'C' source line config statements
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#include <xc.h>
#define _XTAL_FREQ 20000000 //Specify the XTAL crystall FREQ
#define PIR RC0
#define Buzzer RB2
void main() //The main function
   TRISB=0X00; //Instruct the MCU that the PORTB pins are used as Output.
   TRISC=0Xff; //Instruct the MCU that the PORTB pins are used as Input.
   PORTB=0X00; //Make all output of RB3 LOW
   while(1) //Get into the Infinie While loop
    if(PIR ==1)
        Buzzer=1;
        __delay_ms(1000);   //Wait
    else
        Buzzer=0;
spinnaker
Joined Oct 29, 2009
7,830
Debug main Project is disabled for some reason. Never seen that. Do you have a Pickit 2 or 3 connected? Is it a real tool or a clone?
AlbertHall
Joined Jun 4, 2014
12,651
There is no short answer to that question. There are so many things you can do.
However, if you click on the left margin of a line of your code a red blob will appear. This sets a breakpoint.
Now when you run your code in debug mode it will be stopped at your breakpoint and you can view and change RAM and SFRs.
spinnaker
Joined Oct 29, 2009
7,830
In other words:
RTFM
Fanfire174
Joined Mar 13, 2018
240
I was trying to set breakpoints can you tell me how to do it?
AlbertHall
Joined Jun 4, 2014
12,651
Your image shows a breakpoint set at line 21.
If you now run the code it will stop at that breakpoint.
Click the button immediately to the left of the blue MCC shield.
Fanfire174
Joined Mar 13, 2018
240
But we set two breakpoints to find a problem in the code.
Can you attach a screenshot of debugging process?
spinnaker
Joined Oct 29, 2009
7,830
Why don't you read the manual? And there are bound to be tons of generic tutorials on the internet that show how to use a debugger. They all have the same concepts.
spinnaker
Joined Oct 29, 2009
7,830
Learning how to operate the debugger is very easy. All you need to do is follow the instructions in the manual of how to operate the various tools like breakpoints and watches.
You can find definitions of breakpoints, watches etc on the internet. They are common tools used by most every debugger.
Learning how to use those tools to help you troubleshoot your problem is an entirely different matter. I am not sure that can even be taught. It is just going to take experience.
Fanfire174
Joined Mar 13, 2018
240
Start at section 4.17 of the MPLAB(X) user guide and follow that through.
AlbertHall
I followed user guide but I am using letest IDE and compiler There may be some problem
I followed this instruction
File -> New Project
Microchip Embedded -> Standalone Project
Next
Family -> Device -> PIC16F877A
Next
Hardware Tool -> Pickit3
Next
compiler tool chain -> XC8
Next
Project Name -> PIR
Finish
Click on project PIR
source file -> new-> main.c-> PIR.c
finish
save code
click on project -> Build
click on project -> Run
click on project -> debug
set break pont ctrl + F8
But variable value doesn't change during debug process
Ian Rogers
Joined Dec 12, 2012
1,136
The debug facilities on the pic16f877a are extremely minimal... There is no debug header available so you are limited with ICD ( in circuit debugging ) to 1 level, which is rubbish.. If I were you, I would debug on the simulator as much as possible... When I used pickit3 for debugging I only get two breakpoints and that was on a mid range... I since use Proteus.. Real time debugging in a simulator.. Or as near as damn it..
If you are going to use ICD, you will be better off with ICD2.. There is a reason pickit's are cheap...
