How to start 74192 to load preset values
dl324
Joined Mar 30, 2015
18,460
i tried adjusting the resistor higher to 470k still shows 99
For TTL, you should use a longer time constant. For a cleaner reset, you should use a Schmitt Trigger gate which will tolerate a "slowly" rising input more predictably.
You need to work on your schematic drawing skills.
ericgibbs
Joined Jan 29, 2010
21,567
Thanks Dennis.
It works just fine in LTS, are you familiar with Multisim.?
Initially the TS circuit had no Power On Pload pulse, a very basic Pload circuit has been added.
E
brownoutee
Joined Jun 30, 2018
13
sorry im just new to this things
what is a schmitt trigger gate? where do i use it?
JoeJester
Joined Apr 26, 2005
4,390
Is the TS starting the transient simulation from zero volts or are they allowing the DC operating point to be calculated first?
brownoutee
Joined Jun 30, 2018
13
i got it to work by connecting the load to the vcc and ground with 2 resistors
do you guys think this would also work in actual?
is multisim accurate with its simulations?
dl324
Joined Mar 30, 2015
18,460
Multisim is not 100% accurate; no simulator is; that's why you always build the circuit to prove that the simulation was accurate enough.
I know for a fact that Multisim makes inaccurate assumptions regarding the current required to turn on an LED. It forced me to use smaller resistors than necessary, or would actually be used in a circuit.
dl324
Joined Mar 30, 2015
18,460
I stopped using Multisim in the early stages of learning how to use it. I found it to not be very realistic for anything that wasn't digital. I was using the free version (Multisim Blue) which was very limited in the number of usable components available.
ericgibbs
Joined Jan 29, 2010
21,567
Requiring a 1k resistive divider in the Pload line does not make any sense.
I suspect there is a problem with the simulation.
Why don't you just build the Units decade without the 74LS47 and the decoding.
Prove that part and then add the remainder of the circuit.
E
dl324
Joined Mar 30, 2015
18,460
A Schmitt Trigger has hysteresis that allows it to give clean transitions on slowly changing inputs. On normal inputs, the output can toggle when the input voltage is between the limits for LOW and HIGH. Hysteresis addresses that issue.
SN7414 is a hex inverting schmitt trigger.
brownoutee
Joined Jun 30, 2018
13
thanks for the help guys i will just test this in actual see if it will work i wont be simulating the circuit again though cause it seems to be buggy so there's no point. ill update if it works or theres a problem
any suggestion for a better simulator?
absf
Joined Dec 29, 2010
1,968
Does multisim has a way to generate a Hi-Lo-Hi pulse. In proteus, it is very hard to generate a power-start-up pulse using RC circuit. I normally do it this way.
(hope I didnt spoil the soup...)
