How to slow down a electric motor
MaxHeadRoom
Joined Jul 18, 2013
30,771
Thanks just what I am wanting , trouble is if they are from China I may not get it untill quite a few weeks time , I could really do with making one , have lots of electronic parts , would anyone have a schematic of this type of controler ! .
cheers spike
Google Triac motor controller, many pop up.
Max.
wayneh
Joined Sep 9, 2010
18,133
Yes that would work , allthough the motor is quite loud now on full speed ! .
cheers
spike
I suppose you could use both techniques depending on the control you need. The controller will work very well down to - and here's a wild guess - 20% of full speed. If you need fine tuning below that level, you could employ a damper.
AlbertHall
Joined Jun 4, 2014
12,638
I used a standard vacuum cleaner to power a vacuum table on a CNC where effectively the airflow is completely blocked (if you get a good seal) and the motor doesn't seem to mind at all - no overheating. The load on the motor is lower in this condition than if it is pumping lots of air as evidenced by the motor speeding up when the pipe is blocked.
