How to run GPIO code and Tkinter GUI simultaneously on Raspberry?
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
The following script is an stopwatch timer built using Tkinter. I've modified some graphical things. But what I really want is to activate the timer using a GPIO. After initializing the GPIOs and adding the conditions, the extra code never executes. How could I combine them?
The code below is just the original timer without the modifications I refered to.
Code:
import Tkinter as tk
def update_timeText():
    if (state):
        global timer
        # Every time this function is called,
        # we will increment 1 centisecond (1/100 of a second)
        timer[2] += 1
        # Every 100 centisecond is equal to 1 second
        if (timer[2] >= 100):
            timer[2] = 0
            timer[1] += 1
        # Every 60 seconds is equal to 1 min
        if (timer[1] >= 60):
            timer[0] += 1
            timer[1] = 0
        # We create our time string here
        timeString = pattern.format(timer[0], timer[1], timer[2])
        # Update the timeText Label box with the current time
        timeText.configure(text=timeString)
        # Call the update_timeText() function after 1 centisecond
    root.after(10, update_timeText)
# To start the kitchen timer
def start():
    global state
    state = True
# To pause the kitchen timer
def pause():
    global state
    state = False
# To reset the timer to 00:00:00
def reset():
    global timer
    timer = [0, 0, 0]
    timeText.configure(text='00:00:00')
# To exist our program
def exist():
    root.destroy()
# Simple status flag
# False mean the timer is not running
# True means the timer is running (counting)
state = False
root = tk.Tk()
root.wm_title('Simple Kitchen Timer Example')
# Our time structure [min, sec, centsec]
timer = [0, 0, 0]
# The format is padding all the
pattern = '{0:02d}:{1:02d}:{2:02d}'
# Create a timeText Label (a text box)
timeText = tk.Label(root, text="00:00:00", font=("Helvetica", 150))
timeText.pack()
startButton = tk.Button(root, text='Start', command=start)
startButton.pack()
pauseButton = tk.Button(root, text='Pause', command=pause)
pauseButton.pack()
resetButton = tk.Button(root, text='Reset', command=reset)
resetButton.pack()
quitButton = tk.Button(root, text='Quit', command=exist)
quitButton.pack()
update_timeText()
root.mainloop()
