I think it just means it's rated to handle a maximum of 40A going through it.I see that this is a 40A differential switch. What does this mean?
It may just overheat.What will happen if 40A or more flows through this diffential breaker?
A "differential switch " is what others of us call a Ground Fault Interrupter or a Ground Fault Circuit Interrupter . The purpose is to switch off the power if more current flows in one line of a circuit than the other line, with the concept that somebody touching one line is getting a shock. But it will also trigger if the electrical heating tape on your outside water pipes has a bit of leakage, or if the defrost heater on your (grounded) freezer has a bit of leakage current.I think it just means it's rated to handle a maximum of 40A going through it.
Just imagine the excitement when a damaged appliance cord trips the GFCI and the whole house is switched off. And how about a slightly damaged outdoor extension cord that gets rained on during the night. The lights and everything else switch off and the house is dark and nobody has a clue as to why.Also known as a RCD or RCBO in the UK. (Residual Current Device & Residual Current Breaker Over-Current)
Some decades ago, they were made mandatory there in replacing the main disconnect device at the panel, in installations where the traditional methods of earth grounding had been changed, for different materials, PVC's in place of copper/galvanized water pipes etc..
This was where the original practice was to use the metallic water pipe for earth,
They are more likely to be seen in 15a socket outlets in N.A.
Or in the breaker panel for localized installations such as Pools etc.
Nothing strange,! UK, Circa 50,s 60's , your watching TV, listening to the radio, reading, having a birthday party,, all the power goes off, OK Who has a shilling for the (Under stairs) meter.?Just imagine the excitement when a damaged appliance cord trips the GFCI and the whole house is switched off. And how about a slightly damaged outdoor extension cord that gets rained on during the night. The lights and everything else switch off and the house is dark and nobody has a clue as to why.
Not here in the USA , at least not since 1950. I am talking current times, not when you were a teenager!Nothing strange,! UK, Circa 50,s 60's , your watching TV, listening to the radio, reading, having a birthday party,, all the power goes off, OK Who has a shilling for the (Under stairs) meter.?
Most/many households had pay-as-you-go !
Regular occurrence !![]()
I saw that in Ireland.Nothing strange,! UK, Circa 50,s 60's , your watching TV, listening to the radio, reading, having a birthday party,, all the power goes off, OK Who has a shilling for the (Under stairs) meter.?
I should have known if anyone would know it would be you.ChatGPT is a particular version of the GPT3 AI. It is targeting accurate answers to general questions, and it is really very good. But it can only provide general answers and can’t really understand too much about attempts to get more information.
But it does produce cogent and lucid replies. It is in beta right now and you can sign up and try it free, it’s very impressive.
However, this is definitely off-topic so if there is interest starting another thread is in order.
Well a good start of preventative maintenance begins with placing regular sockets and plugs on a regular maintenance schedule for periodic inspection. Actually start by making sure all current carrying conductor are rated for the loads they will see, such as the wire sizes ro outlets. Plugs and sockets need to be kept clean and a plug into a socket should offer some physical resistance going in and removing. They make tension testers for this purpose The longer a plug and socket remain connected wear happens and once any arcing begins it's a downhill slide to a fire. The more heat the worse the connections like a snowball rolling down a hill. Finally you have a fire.Heres some outlets that have burned and melted (before I started rewiring the building). The first one had a kettle plugged into it. The second one an extension cord. They were both pretty old outlets, but I didnt think outlets suddenly become a fire hazard like this after a few years. How can I make sure nothing like this ever happens again?
Wow, I didn't know my father-in-law did any other jobs then the mess I inherited.The person who originally wired the house used really thin wire,
