How to read the ratings of a center-tap transformer?
Michael George
Joined Feb 8, 2015
62
I have this transformer with no datasheet. It's 16V-0-16V and rated for 3A. I'm not going to use the center-tap terminal (the 0V terminal). I'll use the two 16V terminals to get 32V AC. Should I draw 3A ? Or 1.5A?
In other words, Is the 3A for each winding? Or Is this a total power meaning a 1.5A for each winding?
ronsimpson
Joined Oct 7, 2019
4,664
The "BLACK-YELLOW 220" Gives me the idea the primary is 220V.
The 2X16V 3A makes me think it is 32V center tapped at 3A. Probably black/red/black.
The "S. H White - 110" Is there a 6th wire probably with white?
You can use it as a 32V 3A transformer. OR As a 16V 3A plus 16V 3A.
The transformer rating is for a resistive load with no diodes or capacitors. (light bulb for heater load) If you are using diodes and capacitor the transformer should not be used to make 3A dc. I think about 60% to 70% of 3A is all you should get out.
