How to pick a solar panel
oz93666
Joined Sep 7, 2010
742
What do you want them for?
Of course ....you can't just buy a panel without consideration of what battery you will be feeding . ( don't buy panels from that supplier eBay cannot be beaten) .....
A Quick factlet on panels ... the one in your link is described as "12V ...10W " But looking at the specs it has an open circuit voltage 21,5V and delivers max power when voltage is 17,8V !!! so what's going on????
This panel has been designed to connect directly to a 12V flooded lead acid battery , they can tolerate modest overcharging , the falling price of panels has made charge controllers ever more unattractive so if you are going to charge flooded lead acid this panel would be good , no expensive and vulnerable to damp charge controller needed .....
But lead acid is really stone age compared to lithum , and lithium will require circuitry between it and the panel ....
First decide on battery ...
The open voltage and MPPT are typical for panels designed to charge 12 lead-acid battery systems with a PWM type charge controller. Never expect good lead-acid battery recharging from close to full discharge without a proper charge controller connected to a suitable wattage solar panel. Sure, with a few watt solar panel you can maintain a fully charged battery but it will not properly recharge a flat battery.
ArakelTheDragon
Joined Nov 18, 2016
1,366
I want to use it as a power source for a "12V" battery, recharging between "11.5V" to "14.2V". The electronics are not a problem, I intend to use an "LM2596" at 150KHz, I hope its enough.
