How to measure this ?
Hextejas
Joined Sep 29, 2017
187
When I was trying to debug my circuit, I read about transistors and diodes that " the base-emitter junction is forward biased (meaning the base is at a higher voltage than the emitter). "
Hmmm, so how do I measure that ?
1) Power off the circuit.
2) Read the voltage:
2a) Pos on base, com on emitter
2b) Pos on base, com on ground, and pos on emitter, com on ground. Which is greater ?
Apologies for a dumb question.
dl324
Joined Mar 30, 2015
18,326
Measure the base-emitter voltage. For NPN, positive lead on base, negative on emitter; reverse for PNP.
GopherT
Joined Nov 23, 2012
8,009
While the circuit is energized, red probe on base, Black on emitter. Read meter. Should be about 0.6 v for bjt.
Aleph(0)
Joined Mar 14, 2015
597
That's correct for NPN bjt but if they didn't disclaim that (or cop _absolute value_ plea) then authors of resource are ignoramuses that are only worth ignoring:mad:! So just put positive lead of high z meter on base and negative on emitter. Si will be 0.5V to 0.7V and Ge should be abt 0.3V:)
