how to know the current of a transformer
MaxHeadRoom
Joined Jul 18, 2013
30,772
Ampacity of copper wire depends on application, winding- raceway etc.
The rating I have for transformer using #12g is ~13.5 amps.
If the Va is actually 75va then the winding should produce around 6v to be within range.
Or higher voltage with a reduced current, accordingly.
Max. .
Ghina Bayyat
Joined Mar 11, 2018
151
n
Max. .
no it is 12v so the current is less
thanks a lot
MaxHeadRoom
Joined Jul 18, 2013
30,772
You can also run up closer to the gauge rating and monitor the heat dissipation of the transformer, using a suitable primary fuse.
The danger point is always when you approach saturation of the core.
Max..
