How to force like charges on opposing plates ?
yaxlei
Joined Jul 17, 2020
9
Hello !
What would be the circuit to have opposing plates charged with the same charges ?
Is it even possible to do it with an eletric circuit ?
Thank you for your answers
Have a nice day
38,916
You could charge each plate separately with a plus voltage to a ground plate.
Then disconnect the voltage, leaving the plates charged, and then move them close to each other.
DickCappels
Joined Aug 21, 2008
10,661
The charge is not stored on the plates, it is stored in the dielectric (insulation) between the plates.
@ErnieM 's post #5 almost does it, if you want to charge the plates with respect to earth.
I don't think your question can be answered unless you specify to what the charges on the plates is relative.
yaxlei
Joined Jul 17, 2020
9
Yeah I forgot to add that the plates are charged relative to earth
