Solenoid force calculation
moonlystar1111
Joined Feb 1, 2024
106
The formula given in the calculator is
F = (N*I)2 μ0 A / (2 g2),
But it doesn't specify from where the value of 'g' is calculated.
Also, im looking for the force calculation of multilater solenoid.
I'm required to redesign a solenoid bobbin- by reducing it's length and increasing the height/layers of coil winding. So how should I proceed for this?
I came across this formula in a paper, screenshot is attached, which talks about the magnetic field. Would there be any change in force calculation as well?
Danko
Joined Nov 22, 2017
2,241
To obtain absolutely accurate values of solenoid parameters,
I prefer to spend couple of days for experiment, like HERE, page 69.
Relation force from length and height/layers at the same I*n, shown on page 71, Fig. 48.
sparky 1
Joined Nov 3, 2018
1,218
You can apply a force to an electric solenoid that is equal as a vector measured on a force sensor. The field around the solenoid expands or contracts.
Similar to a spring scale. The spring force increases in magnitude at a given distance and the spring compression involves work.
A spring scale is not very expensive. This gives a ballpark reading in Newtons that helps select the right ultra force sensor.
Since the math numbers are ideal, we make a comparison to a reference that approaches best accuracy. A scale is calibrated with a known weight.
Using a sensitive digital scale, a known weight is replaced by a solenoid said to be equal. We can then assign it as a reference and it is repeatable.
Repeatability is the analog proof and when it is expressed in mathematical format it is a reliable solenoid force calculation.
