How to Flash two 240 volt bulbs alternatively
jmarshal84
Joined Sep 28, 2016
2
Hi all,
I'm very new to electronics,
i want to flash two 240 volt bulbs alternatively , how to do this can any one help me to build a circuit for this.
Best Regards
Marshal
dl324
Joined Mar 30, 2015
18,382
Welcome to AAC!
Your requirements are a bit vague. A SPDT switch could do it but, since you're asking for a circuit, your requirements must be more complicated.
34,889
Welcome to AAC.
In order to avoid playing the game of 101 Questions and Answers, you do need to be more up front about what you are doing.
What is the power rating of the light bulbs? We are to assume these are 240VAC bulbs?
What is the duration that one bulb will be lit before alternating to the other bulb?
Why are you doing this?
jmarshal84
Joined Sep 28, 2016
2
Welcome to AAC!
Hi
Thank u for ur reply
My requirement is very simple like flashing two led bulbs using 555 timer ic, instead of led I want to use 240 volt bulbs
38,546
Probably the easiest way while still being safe is to directly drive a pair of solid state relays from the 555.
Depending on how frequently and length of time you want the lights to flash a mechanical relay may not have adequate reliability.
#12
Still playing 20 questions. I would say that I have seen relays rated at 100,000 operations and higher, but we have no information on how many alternations per minute or whether this will be a 5 minute display or a permanent installation.
GopherT
Joined Nov 23, 2012
8,009
Or one part of a bigger project.
"... and I want them to flash alternately every time my girlfriend pops out of a giant cake at half-time..."
