How To Find Out Which Wire Is Ground?
jtrippy
Joined Oct 19, 2016
1
I have a spot light that plugs into my cigarette lighter and I need to replace the plug. How do I find out which wire is the ground since they are not marked?
jtrippy
ci139
Joined Jul 11, 2016
2,006
the automotive spot lights are likely LED-s
since LED-s may have low reverse breakdown voltage you may use 1A 1N4001-1N4007 or more powerful diode in series with your light - then at correct polarity it lights up and at reverse it won't - unless it has an internal "polarity don't care" rectifier - in which case there's obviously no difference
SLK001
Joined Nov 29, 2011
1,549
jtrippy
Just rewire it the same way that it was wired on the original plug.
