You can use a mono stable multivibrator (74123, cd4538, or 555 timer) set to a pulse duration that becomes 10% of your continuous train of square waves. The monostable will be triggered with each positive to negative transition for some of the chips listed - one lets you pick (up or down transition). It doesn't really matter (up or down) since the period is the important part.I need to decrease the duty cycle of a square wave signal.
The signal is 1kHz the duty cycle is 25%.
I need to push the duty cycle closer to 10%.
Any suggestions for a simple means to do this?
Thank you very much for your reply. However, the issue is that I have no other DC or AC input in this case. I only have the PWM here.I assume you mean...
Thank you for your reply. In my case, the PWM wave is generated by a device that is not able to be manipulated. I want to use this PWM signal as the only input to the circuit so that the output would be 10% duty cycle PWM.A schematic of how the current waveform is being generated would be most helpful.
A picture is worth thousands of words.
Right, you can tap into the 25% duty cycle 1kHz signal (1000 uSec period). Use that to trigger the cd4538 chip. Set the capacitor and resistor on the chip to create a 100 uSec pulse. You'll have a 10% duty cycle.Thank you very much for your reply. However, the issue is that I have no other DC or AC input in this case. I only have the PWM here.
For that impedance it would be better to use a CD4538 for the one-shot since it has a significantly lower operating current than the TLC555.the impedance should be 882 ohms.
As were mine.Questions meant for the TS, not a response to your post.
It might refer to one of the elements of a signal envelope along with "decay", "sustain", and "release". They are used in electronic instruments and Morse Code keying in amateur radio applications....
I have no idea what an "attack" circuit is?
Do you mean "added".
Yes, it means "added". I also attached the schematic figure for device A and B in the last post. Please check it. I think the circuit you provided should work. I have not got the component and test it phsycially, though.If the load (not the source) impedance is 882 ohms, which is a low value, then my suggested circuits will not likely work.
Need more info on both the source and the load.
by Don Wilcher
