How to convert 1A to 225mV?
Cao Huy Đỗ
Joined May 9, 2019
Output signal of current transformer is 1A, but input of multimeter is 225mV. So, how to convert 1A to 225mV. Is there current tranformer that convert 1A-->225mV.
38,537
Make certain that the resistor is always connected to the current-transformer output.
Operating it with no load resistor will result in dangerously high voltages, and possible damage to the transformer. :eek:
Reloadron
Joined Jan 15, 2015
7,892
The output of your Current Transformer is more likely 0 to 1.0 amp and 1.0 amp when the CT is at its rated max current. With that in mind rather than deriving an odd voltage I would think about using a simple 0.200 Ohm sand block resistor. The value of 0.200 ohm being more common and with 1.0 amp will show a voltage drop of 0.2 volt or 200 mV. It also makes it easier to convert the voltage drop to current.
You may want to give this a read. You also may want to lend strong consideration to what Crutschow mentions above regarding open circuit voltage.
Ron
