How to construct memory map
IcyIcy
Joined Nov 17, 2012
32
I have some questions that I am not sure on how to do, please help.
Question:
The capacity of a RAM module is 16K x 8. (i) How many address and data lines does this module have? (ii) How many of these RAM modules are needed to realise a memory module with a capacity of 64K x 16? Explain your answer. (iii) IF the 64K x 16 memory module in (i) starts at 0000H, design a decoder to construct the memory module from the 16K x 8 modules.
I am not sure on how to do find the number of RAM modules for (ii) and therefore, not able to construct the memory map for (iii).
My answer for (i) is 14address lines and 8 data bits.
Thanks for your help.
ericgibbs
Joined Jan 29, 2010
21,637
hi,
How many times does 16K go into 64K, and how many times does 8 go into 16.?
E
Draw a simple block diagram if that helps,,, one block = 16K*8
IcyIcy
Joined Nov 17, 2012
32
hi,
E
I get a total of 8 chips of 16K x 8 RAM but, if I use a 3-8 decoder for the circuit. 14 address is used for the 16K x 8 RAM and 3 address for the input of the decoder, there will be a total of 17 address which exceeds the limit of 16 address of the 64K x 16 RAM.
ericgibbs
Joined Jan 29, 2010
21,637
hi,
As you know the Address lines are A0 thru A15, these are common to all the RAM, so consider you have to Chip Select 4 blocks using the 3 to 8 decoder, so you have to decode the higher order address lines to give 4 chip select lines.
Hint:
How many address lines does a 16K RAM require.??
One on the 3-8 inputs could be connected to Zero.
EDIT:
Look at this decoder map.
IcyIcy
Joined Nov 17, 2012
32
hi,
Hint:
Sorry for asking, but why chip selects 4 blocks when I required 8 chips?
There are 14 address line for a 16K RAM.
ericgibbs
Joined Jan 29, 2010
21,637
Because the chips are in pairs to give D0 thru D15 data lines.
So there are 4 pairs, each pair will have its own Select.
Decoding 2 wires gives 4 Selects, if the higher 3 to 8 input is connected Low.
IcyIcy
Joined Nov 17, 2012
32
Sorry for my lack of knowledge, is it means that 2 nos of 16K x 8 bits is equal to 16K x 16 bits (so it means by a pair? when to realise a memory module with a capacity of 16K?)
IcyIcy
Joined Nov 17, 2012
32
But if it is a pair, then when I construct the circuit, I would still have 8 chips? How do I ensure that at each time, there is only 1 chip operating?
IcyIcy
Joined Nov 17, 2012
32
S
A Pair of 16K by 8 RAMs connected as a parallel pair gives 16K by 16.
Look at this image, tell me if you understand it.
Really sorry, but I don't get how the connection is done. Why all the chips are interconnected and not the pair that is interconnected only?
LDC3
Joined Apr 27, 2013
924
You want to access 2 chips at a time (not 1) so that you have 16 data lines (not 8).
After all, the data for the high byte is paired with the low byte; it is not associated with any other byte.
So Select 0 activates the first pair,
Select 1 activates the second pair,
Select 2 activates the third pair,
Select 3 activates the fourth pair.
4 pairs is 8 chips.
ericgibbs
Joined Jan 29, 2010
21,637
I don't know if the connection is like this where all the address lines are connected (A0 - A13) and the decoder is (A14,A15), WR all connected
Usually the Data lines to the RAM are used for both Input [ a Write operation] and Output [ a Read operation].
The WRite pin on the RAM chips select Read OR Write.
The a0 to a13 'single' wire is a shorthand way of drawing all the 14 Pins, instead of a wire for every address pin, likewise with the Data lines d0 - d7 is 8 wires Low BYTE and d8 - d13 is the high BYTE 8 wires.
Do you follow OK.?
