how to check seven segment working or not using sensors?
GopherT
Joined Nov 23, 2012
8,009
@Nanda Kumar 1
Connect a 1k ohm resistor to a 9V battery and then connect a black wire to the battery (-) and a red wire to the end of the resistor that is NOT connected to the battery.
Then touch red and black wires to two pins of the 7-segment display. Connect every combination. LEDs have a polarity so they will not light up if the red and black wires are connected "backwards" so you need to test every combination in both possible polarities.
This will light only in segment at a time.
How many digits is your display and how many pins?
Nanda Kumar 1
Joined Aug 25, 2016
42
@Nanda Kumar 1
@GopherT thank you for u r clear explanation but i dont want that type i want check each segment with any sensor like LDR .
DickCappels
Joined Aug 21, 2008
10,661
Drive each segment according to GopherT in post #8. Take 8 phototransisotrs, each one pointing to one segment plus the decimal point if that exists. You can then "And" the outputs of the phototransistors such that you only get a true output when all segments light.
You can also do that with a video camera but it would be more difficult.
Measure the current to each LED; a faulty LED is likely to draw significantly more or less current than a working one. By measuring the current in the common line it would be possible to check all the segments either together or individually.
dl324
Joined Mar 30, 2015
18,404
Another option is to use one optical sensor and turn on each LED separately. Position the sensor so it can "see" all segments, or use a light pipe to redirect light.
Nanda Kumar 1
Joined Aug 25, 2016
42
Thank you i will try this
