How to boost the voltage from 5 V to 100 V
SamR
Joined Mar 19, 2019
5,542
Perform that feat and I will personally nominate you for the Nobel Prize...
(VI)in=(VI)out - system losses
Requires multiples of this:
Beau Schwabe
Joined Nov 7, 2019
186
It also depends on how long the 100V at 3 Amps is required. You could theoretically get that from a 5V USB port ... you would just have to wait awhile in between each 100V 3A discharge ... <smirk>
ci139
Joined Jul 11, 2016
2,038
? https://www.google.com/search?q=analog+5V+to+60V+converter+-"stpep+down"+-"buck"
https://www.analog.com/en/products/ltc3872.html#product-overview ? use double these (one inverting outp - if applicable ... is applicable for the MC33063 -- it may have more V.out with isolated output)
https://www.electronicproducts.com/DC-DC_Circuit_Calculator.aspx# example inputs ::
\( \begin{array}{l r}{\begin{array}{r|c|l} Input\ voltage & 5 & V \\ \hline Output\ voltage & 40 & V \\ \hline \mathbf{Output\ current} & \mathbf{75} & \mathbf{mA} \\ \hline Output\ voltage\ ripple\ factor\ & 700 & the\ mV\ pp\ and \\ \hline Operating\ frequency & 68 & kHz \end{array}} & {\qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad\ \qquad \qquad \qquad \qquad \qquad .} \end{array} )\
