how to amplification the MCP4261 current
LAOADAM
Joined Nov 21, 2018
956
Used a MCP4261 to generate a signal to control a analog joystick, seems its max current is too small, anyway can amplification it's signal?
Thanks.
ArakelTheDragon
Joined Nov 18, 2016
1,366
The amplification would have to be double sided. Amplify on send, amplify on receive. Are you sure its the current? Maybe its the voltage, coding of the signal, connector or something else?
LAOADAM
Joined Nov 21, 2018
956
here are the circuit and code, the pin6 and pin9 output wrong, p6 = 2.5 V. p9: 0-5V vary, why?
don't know how to upload the code.
ArakelTheDragon
Joined Nov 18, 2016
1,366
I don't see pin 6 and pin 9 to be connected to anything. First if you are using Proteus always connect the pins. Second if you are using Proteus, they have a separate digital pull up resistor and digital pull down resistor, you can not use a normal one. Third, did you check the datasheet, if the voltage is floating that means there is no pull-up or pull-down resistor connected.
